ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
02.23.2011, 05:10 PM
So I got some new goodies coming. All three rides are down but parts are OTW. Raja is getting some FLM 17mm hexes for the 5mm axles up front, as well as a new UBEC from Turnigy ($3.69 - Sweet) I also made some progress on the Roll cage. It came out OK. Not perfect or symetrical but I think it looks good and It should work alright. Just gotta attatch the "Body Panels".
The SC8ight stripped the plastic spur so I am getting a 47t Steel spur off Ebay. The ride still needs a bit of tuning in the shocks but at least It has full new Seals and bearings.
The Maxx is getting some new servos. I sent the Hitec in for Repair and I am kinda disapointed with it. So I bought some Turnigy MG959 Full alloy servos. The Entire case is machined from 6061 and has metal gears. It only cost $22 and has about 190oz/in torque. So I will utilize the Dual servo slots and run two... I keep on breaking the plastic case inside the hitec... So the alloy cased servo seemed like a good option. Unless I can get a case for the Hitec machined... Which I may look into...
http://www.hobbyking.com/hobbyking/s...dproduct=12451
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
