simplechamp
simplechamp's Avatar
02.24.2011, 03:41 PM
OFN36171 and OFN36640, 4mm hingepins for Ofna LX-One are a possibility. Have to email Nitrohouse to get the lengths. I think 36171 will be too long, but 36640 might be close.
EDIT: Nevermind, found the lengths, one is like 74mm and the shorter one only 38mm.
You could use one that is too long, cut one end down to length, and then re-make the slot for the c-clip? Like chuck it into a drill press and use the edge of a fine file. Using a screw is an easier solution I guess.
