03.02.2011, 06:08 PM
Are you sure that was 0.002 seconds? 50Hz equates to 20ms (0.02 seconds). Even still, that's still 5X better than 100ms.
asheck: Just be aware that setting it to 50Hz will reduce the amount of time you can capture data, and it also depends on what data you are capturing. If you just capture battery voltage and current, you might be able to last a whole run, but if you also capture other things (temperature, rpm, etc), your capture time will be shorter.
