03.03.2011, 12:01 AM
Originally Posted by asheck View Post
Sorry, I went with Tekno's so my interest in them has twindled. I will say this, you might want to get started on some front shafts. I totally snapped a stocker off, and I know you have more torque, then mine.
Yeah, you are right. I am thinking some tekno ft hubs, and the bearings are coming that will fit those as well as the rears. Might give the modded lst shafts a try, as the front will see less load than the rears, and I would like to use the pede wheels I have, which means the electric 2wd rears will end up on the front of the 4x4.
I will also be working on a setup for the 2wd pede. I have a big 7th scale 2wd pede based buggy thaty I run a 9l feigao on 3s. It eats driveshafts for lunch.
