03.03.2011, 12:08 AM
Ok, so I broke out the old dx6 I bought a few yrs ago to use with a MOA crawler. Set it up and I think it will work great for the summit.
Will set it up as follows:
Right aux switch will be for the rear diff lock
Left aux switch will be for the front diff lock
Throttle (left stick up and down) will shift the trans from high to low)
Left stick side to side will be for steering
Right stick up and down will be for throttle.
I figured that with enough fooling with trims and epa I can get it to work. I have tested it with a bunch of servos, but need to hook up an esc and see if it will program. My 1st stick radio, feels alot different to a wheel radio.
