DrKnow65
DrKnow65's Avatar
03.03.2011, 09:45 AM
The ESC's (even without BEC) usually pull their own power from the lipo's (what ever the ESC is rated for, i.e. my Phoenix ICE HV works on 12S lipo without getting power through the receiver and it has no internal BEC).
So you pull the red wire out of the Rx connector for the ESC and cover it.
The Rx lipo can plug directly into the "battery" slot in the Rx. Or you could use a "Y" cable on one of the servo's and plug it in there, if you don't have an available slot in your Rx.
EDIT: the turnigy I listed even comes with a receiver type connector already on it :-)
