03.03.2011, 01:09 PM
Originally Posted by bruce750i View Post
IMO, Replace red esc(BEC)wire and let your rx run on 6v, Split the white signal wire from your servo plug, then plug it into rx. Then run the red and black servo wires to the new 2s lipo.
Thats how I know to do it.
Run the black and red servo wires directly to the battery.
Leave the white (signal) wire in the plug end and plug that into the rx like normal.
Leave the esc plug alone so the esc's bec will power the rx with 6 volts.
Bottom line, if you're not sure your rx can handle HV don't do it.
