03.13.2011, 02:00 AM
Here are a few pics to how the wiring setup.
Made an elevated tray to hold the receiver. Use a few diff posts from a hyper7, and a scrap piece of kydex. Also found an antenna holder from a tamiya something or other. The bec is double stuck to the battery vent. You can also see my esc signal wire routing, kinda funny but I wanted to make sure it did not get cought in the outrunner rotating can.
I will say this cc outrunner is very torquey. I currently have the startup at low and with 4s lipo it has a very smooth start in both 1st and 2nd gear. My paralleld 12c lipos are ok, but I have a 6500mah 35c hyperion pack on the way for this build. Should shave some weight and give me a bit more discharge capability.
Everything works great, and I manged to snap a welded cvd shaft, I was jumping curbs. Must do around 30mph in 2nd gear. All temps are great, and it will almost wheelie. I have the punch control set at 50% and may well go up to 75%. No real need for tons of acceleration in this beast, especially with me on a stick radio controlling it!!! I am getting better, but it still feels weird to not use a wheel radio.
