03.15.2011, 02:19 AM
Originally Posted by whitrzac View Post
nobody asked the obvious question...
WTF are you building now??
Ha, well I have had great succes with the 27 series 4 pole aveox in a m03 tamiya on road car. So I was wondering what options we have. a 1406 CC motor is a bit overkill, and the kv options are too high. The 1410 is too long and uber overkill for 10th 2wd. I really think 28 series 4 pole+ motors are a great option.
I did have to use an adapter plate to mount the motor, as it had 16 and 19mm bolt patterns and the 540 std is 25mm. You would laugh at the size of the motor compared to a sliver can brushed tamiya motor, looks to be about half the size. But it puts out 3 times the power, maybe more.
I have some longer can aveox 27 series motors, around 50 mm. I am also looking for some sort of slide on heatsink for the 27/28 series, 360 deg design, with a slot cut to allow you to spring it apart for installation.
