Jahay
03.16.2011, 10:45 AM
Very small update...
Still waiting on a whole load of parts before things can progress which is really frustrating...
New Era are probably the worst people i have ever dealt with... They have no responded any of my emails! Never will i be giving them business again, and discourage people to buy from them unless really necessary and you cant find the parts you need.
Anyway...
Firstly... Here is my new motor mount spacer so i can run mech brakes... Designed by the one and only Dejan once again! He has done an amazing job once again and turned them around in a couple of days even though he is extremely busy! THANKS DEJAN
And as this is not going to be a hardcore basher as in it wont be doing the same huge jumps it once was (i have my second flux for that) i thought i would try and improve the handling and take off on this XXL... I thought i would stiffen up the rear arms with some carbon arms from Vantage racing... I do not want front carbon arms as i need the flex when cartwheeling (i always broke front arms, never have i broken a rear arm in a cartwheel... It is because the majority of the weight is up front)
Im going to have to work out a way of mounting my sway bars to them and my rear mud guards too....
Next are my new 23mm extended hexs... These will be anodised Red as well
They will be extending my width because my SPIs are going to be shelved now for these below :)
I will be running red plastic beadlocks from MMR... Should be awesome... yes they are heavy but they will offer stability at speed and NO BALLOONING
Desperados and BowTies ----- I didnt want Hostile tyres as the side grip is too much resulting in roll overs... The bow tie will allow me to drift corners nicely but give me great straight line grip and acceleration due to the huge tread... People say they also wear down quickly... but this happens on bajas which are 10lbs heavier and all there weigh on the rear tyres. Which is the opposite to my setup.
