Originally Posted by Jahay
Brian, you are right... im running 4 rear bow ties... i have the blue foams which seem to be very stiff... i cannot see these tyres ballooning at all...but maybe i could be wrong.
BRIAN - also wit the hexs, i found that the 3mm pin is quite difficult to slide in... i take it is meant to be this way so it doesnt fall out? Do yours behave like this?
My rears were ballooning some for sure - I thought it was making the truck a little squirrely under acceleration - so I taped them.
The 3mm pins I use go in fairly easily - it's the set screw inside the axle that holds them in place. I can get an exact measurement of my pins when I'm home and you can compare.
-brian
