Thread: Castle 1410 1y
Thomas Porfert
Thomas Porfert's Avatar
03.16.2011, 10:56 PM
Originally Posted by hootie7159 View Post
I run mine in my losi scte...geared 16/40....2s 65c 5600mah proteks...back to back runs without any rest (except to swap out lipos) will get this motor up too 200F...(on a 1/10th scale track pretty decent size)..it's a good thing the windings and magnets can take temps waaaaay above 200F... ;)
Just be careful with those numbers.. That magnet can handle a bit more than 200° F, but I wouldn't say way more though; and remember the temp on the outside of the can is not the temp of the magnets. I would let that little guy get a bit of rest in-between batteries; it's a good motor, but it does have its limits.
I am curious about that setup in the new Losi SCTe. We haven't received one to test with yet, and it is a bit heavier than the other 4x4 short course trucks. With that gearing on a single battery run, what kind of temps are you seeing on the motor? And are you using the Sidewinder SCT ESC or a Max Pro? Thanks!
Thomas Porfert
Tech Support
