03.23.2011, 12:23 PM
I don't see the interest to use the 2650Kv with 6S when you can use the 2200Kv with 6S... With a bigger pignon, the 2200Kv will provide the same speed at a better efficiency and with less amp spikes in the ESC and the battery....
What's the matter ? You can't find a pinion big enough to do the job with the 2200Kv ?
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
