asheck
03.24.2011, 02:49 PM
Here, between the 2200Kv and the 2650Kv, the difference does not come from the windings but from the length of the rotor (both motor have same windings 1Y and same windings thickness).
My example is stemming from a 1410 compared to a 1415. So both 1y
Here's my 1415 on 3s, running 49mph, on 3s in my Pede 4x4
Here's my 1410 running 49mph on 3s.
Here's my 1415 on 2s running 30mph
Here's my 1410 running 33mph on 2s
The max amps, and the average amps are both higher, with the bigger motor. Even though the speed is the same or lower. Now, it's all pretty close, so I would assume the 2650 and 2200 would be even closer. But I logged probably 10-15 runs with each setup, and the 2400 always drew more amps, and averaged more.
You can't judge efficiency off temps when you are dealing with 2 different sized motors, as the bigger one will always run cooler, given the same load and efficiency. IOW just because the bigger motor is cooler, does not tell you that it is more efficient.
