brian015
brian015's Avatar
04.01.2011, 07:35 PM
Originally Posted by Candyman2 View Post
If your putting a centre prop shaft in make sure you use something like 8mm/10mm tube to extend it. Dont be tempted to use bar as it will bend, has to be tube.
This makes no sense - a solid rod is stronger than a hollow tube of the same OD.
