Thread: cc bec question
Remove tray
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Remove tray - 04.04.2011, 05:04 AM
Originally Posted by slimthelineman View Post
Thought of that but not sure how I would know when I was aproaching the lvc of 9v for the 3s unless the cc bec has a lvc built in. Haven't been home to mess with it been on storm work for the last couple days bit I will mess with it tomorrow. Also the small 3s I have is too long I think to cram inside the tx where the four aa batts went. I'll post a pic or two of the whole setup when I'm done.
Brian G actually did a conversion thread on this a while back and once you open up the radio you can totally remove the 4 AA battery tray and place somthing else in its place if you wish. I am doing the same conversion on my DX3R but using a Hydromax NMH battery pack. I like the idea of using the CC BEC though to protect the radio, but not sure if you need it. Do a search in here for DX3R conversion and you might find that project that BG did. Good luck with that and let us know how it works out for ya.
SUPERMAXX YOUR LIFE.
