brian015
brian015's Avatar
04.05.2011, 03:39 PM
Originally Posted by thzero View Post
That's basically the stuff that I was using when I was running 23mm hexes. And yes, couple of wraps and make sure that the fit is snug.
Exactly - I found my aluminum tape in the ventilation/ductwork aisle at the Home Depot.
And someone else cut a strip of aluminum from their coke can and put it in the hex to fill the space - you could even super glue it to the hex so it stays put when you mount the wheel.
Edit: link to coke can reference
