Originally Posted by simplechamp
I'm not familiar with the vehicle, but after looking it over on the Tamiya website I think you'd be better off with a Castle or Tekin 1/8 brushless combo on 4-6S lipo. Tamiya lists it as a 1/8 truck and it looks to be similar size to T-Maxx, Revo, Savage, etc. I don't think the VXL system would work out, at best it would get hot and be underpowered, at worst it would go up in smoke.
I haven't seen one of these converted before. There are a few different things that could work, depends how much you want to put into it. You could make a custom mount, and keep the transmission (although not sure the 2-speed would hold up or be the best choice). Or you could get rid of the transmission and go for a center diff with the RCM mount: http://www.rc-monster.com/proddetail.php?prod=rcmcdmm You could also use one of the other mounts from a variety of buggies and truggies and use the center diff assembly from one of those.
I don't know if the RCM Revo mount could work, might look into that too.
thankīs for the info and at the moment the doubt is reaally if it will run ok on 3s lipo.
i was thinking buy a 2650kv castle motor and a hobbywing sc esc and run it on 3 lipo.
i like light setups and i donīt wanīt more that 30 to 40 mhp...
thankīs
