brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
04.12.2011, 08:34 PM
I think it has to do with that and that the pinion isn't quite parallel with the spur because the bracket I bought was not quite 90 degrees. I think the whole thing moves slightly whenever I hit something or take a jump. Probably bends the mount some too. I need some machined aluminum or steel. The stupid pinion always comes loose and slides down the shaft too. I was just going to buy a 40t steel Integy spur and the Integy mount, though I know their molded aluminum isn't worth much. I think I'd probably have to put spacers on that mount too because it won't put the motor close enough to the spur.
I've seen other clones on eBay for about $50. I can't seem to find anything decent for that price tho. That's the problem with Mike's quality mount; nobody ever sells it -.-
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
