DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
04.15.2011, 07:36 PM
Are you recalibrating after you change the epa each time?
Can you set 150% for throttle & 100% for brakes independently, or is there one setting/adjustment which affects both brakes and throttle at the same time?..
yeah, i tried re-calibrating after every change. maybe the brakes not being as good on 150% as 100% is in my head. i am afterall going faster than the 100% setting on the throttle i just figured i'd see a bigger difference in brake because the top end difference is large.
i changed the brake curve to an almost vertical line and that helped alot.
so i think i'm going in the right direction now...thanks to Brian and Neil for the advise.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
