I also cross drilled the bodyclip holes to prevent them from bending and popping out when flipping over or landing on the roof:
I installed a enginehead protector from a X 4.6 to give the rollbar and the rear tower some support from eachother:
And as you can see I did put a nylon sock outside the MMM since my outwears cover hadnīt showed up at the time
It all came along nicely!
I would like to say thanks to all the members who builds and modifies stuff each and every day for all your informational threads and posts.
I still have alot of work to do with the truck, I havenīt decided if Iīm going for rpm arms or not, If I should go for Tcs 5mm chassis or not or If I should stick with the stock bulks, get bashcat braces or alu bulks. I have ordered more stock braces and will first of all try to do my own cheap version of the bashcat braces. Only time will tell what needs to be upgraded.
And... The MMM got it outwearscover now and I changed my castle/neu for a 2350 that I had laying around Since Iīm only running 4s for the time being
Thats all for now I guess
