Jahay
04.18.2011, 06:21 PM
Thanks for the info bud... it just reminds me to locktite as i go... THere are many things i havent loctited because i continuously rip it apart and put it back together.
The only weak spot at the moment, which i believe wont cause problem, are my front and rear plastic diff cup cases.
they are from a vorza and very tough. And allows me to use my BP Savage Ring gear and hardened internls which are tougher than a stock savage... Plus i use two larger 8x16x5mm bearings instead of the old alloy cup bearing which was 10x16x5mm. Im sure the cup will handle the power. My CD is a spider diff, so should be all gd there.
Hopefully you get it all put together soon!
Any update on how you found the handling with the narrower front hubs you shortened? There is a guy that may do mine and shorten them to 20mm rather than 30mm. Think it is a good idea?
