Manne
04.19.2011, 03:15 AM
Ola:
I agree, It can be top heavy, but mine isnīt, the half offset wheels and the truggy tires really helps to prevent side rolls and wheelies I also think that the reduced weight makes a difference.
My friends truck is a totally different animal, he is using stock tires with stock rims, his suspension is HARD, thick oil and heavy springs, you canīt imagine that itīs the same platform when you see the two truck togheter, we will be working on his suspension setup asap.
Thzero:
Overdriven is right Itīs not the nitro gearbox, itīs the gearbox for the brushless trucks, and I would say that it is the most durable one out there. I have used the same gears in the gearbox for two years, and that is with the slipper locked with screws, the gearbox is the only thing that I didnīt break on the revo, Itīs very rare to see these gearboxes breakdown.
Yes! changing pinion takes about 30seconds. Open the setscrew-take of the pinion-add locktight-install the new pinion
I have thought over this whole battery box situation, I have pushed It bretty hard and yes they pop open so I will get some velcro right there, I have also managed to "break loose" small pieces from the lower mounts to the boxes so I will get the Gcm kit :).
I donīt think I want to flipp them around, I have no problems like it is right now and Iīm afraid that I will break the tabs on the batterybox if I flip them around since you have to remove the little "triangle" support on the upper tabs on the box itself but thanks for the tip anyway, Iīm glad that you like the build.
E-revonut:
Eeehh.. I donīt want to say it because itīs GPM hubs..... but they have been working really good so far! And I am not gentle with it
Iīll post some pics from the last bash, sadly we only took pictures when I jumped the smaller jump in the pit
