Thread: Solder Tip
BIG-block
04.19.2011, 10:12 AM
I love using lead free solder. On all of my battery connectors and motor connectors I exclusively use lead free solder. It is a lot stronger than the 60/40 mix and flows a lot better if you have a soldering iron that can do the job properly. Lead free solder melts at higher temps so it might not be a best thing for really small components on a PCB but on bigger stuff it's all I use.
