Jahay
04.20.2011, 05:28 AM
WhatsNitro - Thank you for the diagram bud!!! Appreciate it.... Duh i knew it was set up like that... i used to run bloody mech brakes on my old MMM! lost my head at the moment!!!
Anyway, at least that is sorted....
BUT i went and took measurements of my bullets and my ESC Cables!
I think i need larger bullets!
Internal Diameter of my 5.5mm bullet is 4.13mm
Diameter of ESC Wire which connects to lipos is 4.59mm
So that wont work! That is the ESC Wire lightly tinned and squashed as tight as possible!
ESC/Motor Wires
6.5mm Bullet Internal Diameter is only 4.44mm! WHATS UP WITH THAT?
Diameter of ESC Wire is 5.05mm!!!
NO WAY can these wires fit in these bullets!!! The gauge of wire is obviously too large.
I cant even fit the ESC to Lipo Wire in the 6mm bullet!!!!!
What bullets do you run brian as i know you have the same ESC... I dont know why the gauge of wire is so large as i should defintely be pulling less amps with more cells!
