Originally Posted by Manne
Super small update:
I have a troublesome heat source in my truck.....  .
Iīm using 4s 25C 7400mah rhino lipos.
First I was geared very low, 36.22 mph (58.18 km/h)@3.7V per cell, and with that gearing the temps were fine but the truck was just silly slow.. So I regeared from 65/21 0.8mod To 47/17 Mod1.
From that Iīm getting 40.55 mph (65.13 km/h)@3.7V per cell That is totally okay with me but the temps are trough the roof.... I donīt know If I cooked the 2350... It cogged like crazy in the end of the run, only from a complete standing tho so I donīt know what was wrong... I could run it in super slow "crawling" speed but it was as I said very coggy from a complete stand still...
I will try with my Neu/castle 2200Kv and see if the motor is dead, add a CC blower or just a computer fan and then we will then see If I need a 1520.....
it sounds to me like you cooked the motor unfortunately. i think either that 1515 1y 2200kv motor should work fine or maybe a 1518.
love the build! i am currently scavenging ebay right now to get some parts that i need thanks to a screw-up on my part. i tried to add some jb weld to the 14mm hexes in some of my older tires' hexes and mounted them with the non-dry jb weld in an attempt to get a tighter fit between the hex and the wheel. it worked for a little while until i broke a knuckle and realized that i had effectively jb welded the hex to the axle. now, i already have the new knuckles and am looking for cheap axles. i am also looking for new dogbones because those are worn out and need to be replaced anyway.
