CellPro PowerLab 8 Battery Workstation.
MindThoughts
CellPro PowerLab 8 Battery Workstation. - 04.22.2011, 05:27 AM
Thank you for the picture and detailed account of your experience.
What will you do next, in order to repair the damaged part? It may be a very low fee to send the charger back in to the manufacturer for a repair estimate, and or maybe this part could be processed under warranty. I do not know for sure. I also wonder if any aditional part or parts may have been damaged, beyond the one piece we can see in the picture. What are your thoughts about this at this point in time?
Note: Now that Thunder Power is offering their G6 series LiPo battery which can accept a 12c balanced charge rate, with said no discernible cycle life loss, nor battery damage- I'm very interested if our PowerLab 8 CellPro Chargers can accept another Firmware update which would allow this model charger to charge at an amperage of possibly 50amps, or even 60amps; or more.
I remember speaking with FMA Direct's Tech Support Howard Matos. Howard at that time- which was many months before the PowerLab 8 Charger was released for sale, and FMA Direct was accepting pre order payments at a reduced price to anyone that would like to pay in advance. I had ask Howard why they did not make the charger more powerful than 30amps- which at that time was the said limit of the chargers power, abilities; and potential. Howard explain that the 30amps was the safe limit of charging power for the hardware in the charger.
Many months later after I received my PowerLab 8 charger, I learn that there was a firmware update which permit an additional 10amps of charging power. Simply with a five minute free firmware update to the charger, now permitting a 40amp balanced charge rate.
When I ask Howard how this was possible, when he had previously explain to me that the hardware would not handle any more power; Howard then explain that this was previously kept secret in order that anyone building chargers that would match the original 30amps of power, would no longer be able to compete with the now more powerful 40amp PowerLab 8. And sure enough- I've seen a couple different 30amp chargers on the market- but only the CellPro PowerLab 8 can balance charge at 40amps.
This makes me wonder if the CellPro PowerLab 8 is still capable of more power by way of an additional firmware update, than the now 40amp limit of the charger. I still find it quite amazing that I use to go to the RC track with a small case of batteries and five chargers, all charging at 1c or 5amps for a 5000mah LiPo. Now I bring my one PowerLab 8 40amp 1344watt Balance Charger, and two- 2cells, running one 2cell while charging the other. In my 1/8th scale Hyper 9E I'm running 18 minutes at race speeds with the 50c 5200mah 2cell batteries, and the charger is always complete with charging well before I get back to the pit area for a battery change. The 50c 5200mah cells are the G4 technology, I believe. Thunder Power already has the G6 series available and these newer technology batteries can accept a 12c quick charge rating.
The next test I will be conducting will be running a battery with just enough Mah(+ a little extra Mah to prevent from overdischarging the battery) to complete a 5 minute qualifier, and possibly another battery with the minimum Mah/Capacity to complete a 7 minute main. Based on the fact that my run time is 18 minutes, and I'm charging 4500Mah back into the 5200mah 2cell(note LiPo cut-off set to 3.3volts per cell) on the Mamba Max Pro Speed Control- I may be able to use one 2cell 3300Mah or possibly one 3cell 3300Mah 65c if extra power is needed. This minimizing of battery capacity/Mah would be primarily to reduce unused- weight(battery capacity) in the qualifier and main race.
Note: The reason I'm able to run one- 2cell LiPo in a 1/8th scale buggy is because I believe the full carbon fiber kit(by Matrix Concepts Inc) reduces the overall weight of the buggy enough that I'm able to also run a short course truck motor(Steve Neu/Castle) 1409 1Y 3600kv which is the same exact size as the Novak 17.5 stock 2wheel drive 1/10th scale buggy motor- in terms of outer motor can diameter and length, and weighs only 219grams- and has a 5mm pinion gear shaft(accepts Mod 1 Pinion Gears). The buggy is as fast, if not faster than any of the buggies running standard 1/8th scale motors- powered by 4cell at 14.8volts.
PS. If anyone is aware of a Balancing Charger which charges at a rate beyond 40amps, please post onto this thread the link and any information. Even if the model is not yet released- but in the design stage of the process :) any information will be greatly appreciated. As said by other RC enthusiasts the world over- a huge step in the right direction would be to integrate the power
supply into these high powered balance chargers.
Hyper 9E And Losi 8ight-E. Each model with Full Matrix Concepts Inc Carbon Fiber Chassis & Kit. Xcelorin 2100kv + Xcelorin ESC & 1409 1Y Neu/Castle + MMM. 1344watt 40amp PowerLab 8.
