Manne
04.24.2011, 09:36 AM
Iīm using a savage spur #76937, and just a mod 1.0 pinion/5mmshaft, canīt remember the brand but any would work goog with the plastic spur.
18/47 is the smallest gears you can use without grinding any material off the gearbox, I havenīt tried 18/47 with the 2200kv, that can i slightly thicker, so It might not fit/get good gearmesh.
I ordered some 49tooth spurs but I donīt think they will fit inside the chassis :), I have made a "slot" in my chassis to make the 65tooth 0.8mod to fit, so it doesnīt mather to me, just letting you know if you are makeing the swap.
