Manne
04.28.2011, 05:06 PM
Update!:
The raw power of brushless:
The truck is running great! I have broken a few things now tho.. first up, a-arms, no biggie, five arms so far, all lower and one upper Installed rpm a few days ago and they are working great! No broken arms so far since the install!
I also broke a screw in the steering assembly:
but I got it out with a plier:
And then I installed a finethreadded screw instead, The stock screws has too little meat on them... But I do like big threads.. The best would be something between Traxxas "finethreads" and hpi threads "Fatthreads"
I installed the mod 1.0 gears and the slipper plate from a Savage on the Revo gearbox:
I had to drill up the hole in the shaft from the revo gearbox from 2mm to 2.5mm in order to get the right "drivepin" in for the Savage slipperplate, and the slipper plate´s hole is to big for the shaft...But the spurgear will still be perfectly centered since the hole in the spur and the bushing ( or ballbearing ) has the correct inner diameter.:
