sikeston34m
sikeston34m's Avatar
05.11.2011, 06:40 PM
You need to go up to at least 6mm bullet connectors, and maybe larger. I saw that you are using 10gauge and 4mm connectors. 4mm bullets are not big enough. Plus you need the good bullet styles, like castle sells.
Also, reduce wire length wherever possible. Even an inch here and there translates to alot of un-necessary wire.
Looking good, glad you are having these great results!
It's funny how voltage goes through the converters.
Watts in = Watts out
What I mean is, if I'm drawing 50 amps on the low voltage side, on the high voltage battery side, it's only 25 amps.
I figured the 4mm bullets and the 10Ga. would be enough for that.
It's on the low voltage side that I really need to increase the wire size.
I verified all of this with a watt meter.
It's funny you mention the wiring thing though.
Last time we went fishing, I forgot my 7 foot 10Ga. "extension cord".
This forced me to move the power alot closer to the motor.
Voltage drop was less and total watts was considerably more.
I need to go bigger between the converters and the motor for sure.
