pinkpanda3310
pinkpanda3310's Avatar
05.12.2011, 11:26 PM
When I was trying to learn about lipo's I had heard of them exploding during charging but that was from using the wrong charger (nimh) or trying to charge dead or disfunctional cells. I haven't heard of someone deliberately charging more than the C rating.
The FMA can balance and charge at that same high amp rate. Like I said, you have to try the FMA to believe the true high speed charging. The A123's get charged at 20A now. That is limit of those cells.
One or two of my A123 packs were make up's from disfunctional dewalt packs so they have mixed resistance and life cycle (yes, I know, my bad ). Didn't think it would matter that much 'cause of the relatively safe chemistry. There still going strong
What I would like to know is how does the FMA keep up the charge rate on unbalanced packs when the balance tap is only good for 2 amps?
