brian015
brian015's Avatar
05.15.2011, 07:17 AM
Originally Posted by Bmr4life View Post
Wow, so you wrapped a hack saw blade with tape and went to town huh? How long did that take?
Actually, I was able to use the regular hacksaw with a 12" blade for about 9" in from either side. Then the frame of the saw got in the way of cutting further. It was only the center 6" or so that I needed the blade with the tape handle. It took a little time and patience, but with practice, I've found that I can cut very straight with a hacksaw - its long straight blade can serve as a guide once the cut is started.
