Thomas
Thomas's Avatar
05.15.2011, 05:50 PM
Originally Posted by JoFreak View Post
... Give the switch a plug at the ESC case. So those of us who don't want/need that switch can simply unplug the switch wire harness and put one of those little jumpers (the ones we used to jumper IDE computer drives for master/slave for example) in there.
It would be even better if the switch wires didn't transmit power, just the signal, and "open loop" was "ON". Thus, you could simply cut off the switch and a broken wire would not shut down the ESC.
