05.19.2011, 05:55 PM
The RPM wear plates are not designed to replace the skids, they go over the top of whatever skids you use- stock is fine since the G4 doesn't use special length skids front or rear, just regular ones ( the old G2/3 extended version chassis used a longer rear skid and rear upper chassis plate ).
