JoFreak
JoFreak's Avatar
05.21.2011, 03:57 AM
Originally Posted by traxxasbasher13 View Post
...or a real 1409 ($159)
If only it was 159$.
Try adding 30-35$ shipping and another 20% fees and taxes.
none of the other motors mentioned are 4 pole.
Well, apart from the Lehner XL (1920 was excluded from the start because of it's price tag) every other motor is 4-Pole.
Lehner would be the only exception for a 2 pole motor.
The Plettenberg Extreme is from the HP220 line of motors and according to the Plettenberg website all HP220 are 6 or 4 pole motors.
The Neu 1409 and the CC 1410 are both 4 pole as well.
The 1410 is your best bet. With a matching Castle Creations speed control you can adjust it to not seem overpowered.
Castle ESCs are great, but not what I want in my 1/10th 2WD cars.
If I should start driving in competition (which is my goal) I need to use those efra cans and a sensored ESC. That leaves only the MMP.
That won't fit behind the battery in my SC10, I don't trust the BEC and an external BEC is out of the question in my 2WDs for several reasons.
Apart from that I want both my 2WDs to have the same ESC.
And there is no way I can fit that huge MMP into an Associated B4.
So at the moment I'm thinking Tekin RS Pro?
Don't know yet if it's able to handle 4 pole motors, but I guess it does.
The lehner basic xl motors are fantastic motors, but they are 2 pole. A lehner basic xl would also be an excellent choice.
Good to hear, will keep that in mind.
better question, what are you doing with it? racing?
That's the goal. For now it's practice, practice and more practice.
So I need to be able to get serious runtime without having to worry about my motor catching fire all the time.
I run/have run a tekin 8.5 and tekin 10.5 in my sc10 with both a Tekin rs and a Mamba max pro. ... None of the setups ever required a cool down period ... It would come back after an hour and a half of continous running and only be at 120-130 on the motor and the same for the esc.
Sounds great, but I just can't imagine it. I mean, the Tekin Redlines are built similar to all the other roar/efra cans. So how is it possible that, after over an hour, it is ~86°F cooler than all the motors I tried (Speedpassion competition V3 13,5T, Hacker E40 13,5T, LRP X11 10,5T, LRP X12 13,5T) after ~20 minutes?
another thing is you can always toss in a 13mm rotor in the tekins for a nice boost in torque and a larger range for gearing.
This sounds like something to keep in mind if I should eventually need to get a Redline for racing. Does that bigger rotor really make such a big, noticeable difference?
Gearing is the issue with any roar motor. Don't over gear it and you can run all day!
Well, shure, but I'd need all day to get arround the track as well.
Nah seriously, if it get's any slower then the X11 10.5T geared as is, I might as well stay at home, because it would bore me to death not being able to keep up with any one else.
To further clarify:
I want that motor for track practice and fun races that don't regulate what motor I can use. I'll get a roar/efra motor to use if required.
Thank's for your ideas so far, keep 'em coming
I also found this motor:
IN-RACING Afterburner 3650 - 3300 RD 3
Definately looks good on paper. Apart from the low recommended temperature of 60°C.
They used to sell rebadged Medusa motors. Don't know if they still do with Medusa being out of business. So no idea what that motor could be.
