v8hatch
v8hatch's Avatar
05.22.2011, 10:21 PM
I have been running the Baja in sand that’s a little wet and have found that it builds up in the inside of the rim, it makes the rim very heavy and unbalanced and because of this the Hex’s and hex pins aren’t liking it at all. I have got hold of some 24mm hex bar so I can make some hex’s to the length I like and sort out how the pin’s fit, might either go with 2 pins or 1 bigger one. I could even move the pin closer to the outer end of the shaft.
May even make up some longer drive cups so that the load spread’s the hole length of the hex.
