armourbl
05.26.2011, 10:42 AM
Originally Posted by kingdomracer View Post
I've experienced this where a hub pin is broken and you can't see it until you take the hubs off.
Come to think of it make sure your center drive shaft is working with both front and rear hubs attached properly to the center diff/slipper clutch and the front diff too.
Once a set screw was able to back out and not until I took it apart I didn't see it.
This is a 2wd Slash.
Power seems to getting to both wheels, but more to one of them. If I hold the truck rear bumper, it lays an even amount of rubber on the ground. To me this means neither side is really slipping or losing drive.
ben
