slimthelineman
slimthelineman's Avatar
05.27.2011, 08:03 PM
Sounds like your diff is not working properly at all. Under braking if one tire locks up the other should do the same cause the motor won't let anything spin. The fact that one tire still spins is highly irregular. Check your susp for binding and make sure your right side slider is not stripped or the axle pin has not sheared behind the hex. The 1406 put out crazy power and is capable of destroying said parts. I'm still waiting for cc to release the rebuilds so I can get a new front endbell on mine and put it back into my lcg slash for more punishment.
