Pdelcast
Pdelcast's Avatar
06.03.2011, 03:39 PM
Originally Posted by nvtuning View Post
i understand those connectors are bad but 25C on a 5400mAh battery is good i think
better 25C on a 5400mAh battery than 40C on a 2200mAh one
greets nvt
That's true -- 25C on a 5400mah battery IS better than 40C on a 2200mah battery -- but I personally wouldn't recommend either of those batteries with a Mamba Monster.
All of these things add up to make it hard on the ESC, and especially on the capacitors.. The capacitors are there to keep the voltage at the ESC as smooth as possible. If you use connectors that are too small, and batteries that are too low C rating, the results are damaged capacitors.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
