nvtuning
06.03.2011, 03:56 PM
That's true -- 25C on a 5400mah battery IS better than 40C on a 2200mah battery -- but I personally wouldn't recommend either of those batteries with a Mamba Monster.
All of these things add up to make it hard on the ESC, and especially on the capacitors.. The capacitors are there to keep the voltage at the ESC as smooth as possible. If you use connectors that are too small, and batteries that are too low C rating, the results are damaged capacitors.
Thanx!
Patrick
ok i'll try to change the capacitors and see if it works and get some new battery's thanks for your help
greets nvt
rc8te/NEU 2200kv/mamba monster/4cells lipo
savage/castle 2200kv/mamba max pro/4cells lipo
scx-10/castle 4600kv/mamba max/2cells lipo
