Thread: New Monster?
BIG-block
06.04.2011, 09:09 PM
I can't see sensored being that hard given they have the MMPro...
Data logging I think is just added expense and weight - 98% of people just wont use it or care. I know I used it a few times with the Baja's and now just don't bother...
Arct1k that is the whole point with the data logging feature and that is the grates thing about brushless "Set and forget" (other than power). No way anyone is going to use it every time. It is meant to be used to check your setup and see if batts and gearing is up to the task. After you work out everything is fine data logging is something that will get used next when you make serious changes to your car. Eg, different size wheels, running in sand, new batts..........
The way I look at it having a data logger built into the ESC makes life so much easier and well worth the expense. Buying an additional unit like Eagle Tree data logger will be more expensive and more of a hassle to hook up and secure to the car for a test session. It just makes sense to me.
Patrick, great to hear about the new FETs. Way to go man. I like the way that you guys just never sit on your hands but instead always looking at new way to improve your product line.
You guys know I can't comment on what hasn't been released publicly yet.
Well next to "Yes, the new MMM Pro is coming out soon!" that ^ is probably the best thing I have read in this thread.
