florianz
06.06.2011, 02:41 PM
it depends more on the kv / rpm you choose. I think with something around 1400kv or lower, on 6s you should be fine. a proper gearing is also important, geared to the moon you would kill any esc. xerun/ezrun are solid ESC's.
you could also go for a leopard 4082.
probably you should get some 25c lipos. Nevertheless, those C-Ratings are often marketing. Personally, I don't see any difference between my 30c- and 20c Tunrnigy lipos. they both get warm, they both have some voltage drift, they both are good batteries.
when they are testing lipos, in some cases it shows that the actual c-rating is lower then the rating on the pack. even with brand lipos...
I think the muggy is a dammn cool car. go for it! and please, report the build here.
