sikeston34m
sikeston34m's Avatar
06.08.2011, 05:38 PM
HV is good to have as long as the required amount of wattage is met for your setup. However you can only go so far as weight becomes an issue and throws out your gained efficiency.
One point here is, with the higher voltage setup, the amp load demand is less.
This allows you to consider smaller mah cells that make up the HV packs.
Instead of going from a 4S 5000mah pack and just adding 2 more cells, for a 6S 5000mah pack.
Perhaps going with a 6S 3000mah pack would help offset the weight penalty.
