crazyjr
crazyjr's Avatar
06.08.2011, 09:07 PM
One point here is, with the higher voltage setup, the amp load demand is less.
This allows you to consider smaller mah cells that make up the HV packs.
Instead of going from a 4S 5000mah pack and just adding 2 more cells, for a 6S 5000mah pack.
Perhaps going with a 6S 3000mah pack would help offset the weight penalty.
My point exactly, with higher C-ratings, smaller packs can be used, Which adds to the efficiency thing. I have room to grow on this 1/10 project, The Lehner is good for 60,000 RPM, so 8s+ is possible with this setup. I figure two 1500 mah 4s packs will fit in a T4 tray, Just need an 8s capable esc small enough
This is good, something i can contribute to with experience.
