T-birdJunkie
06.10.2011, 12:17 PM
Originally Posted by brian015 View Post
Dude, I'm not quite sure what you're talking about here, but I think you need a new barber. I didn't know what a "comm cut" was, so I googled it and came up with this guy:
If this is you, then you definitely need to make a change - tell your barber you no longer want the "comm cut" and go for something else. And he's ripping you off if you have to go back every 2 weeks for a new cut.
Another thing, when you say "a cleaning here and there" - the way most of us clean our hair is when we take a shower, is that what you're talking about?
And the "occasional brush swap" - I'm not sure it this is coded language for something kinky or not, but I'll tell you that I've had the same hairbrush for the last twenty years or so - I think it's made of genuine horsehair - but let me say that you get what you pay for - so you need to invest in something that will last.
Anyway, I hope this helps.
You made it go POOF but you could've made it go faster by using 6s
Originally Posted by bruce750i View Post
Bruce750i says too high of C rating blows them every time.
Originally Posted by brainanator View Post
Probably the headlight fluid. Either that, or double check the muffler bearings, ever time they make one revolution 1 ounce of grease should drip on the floor. Any less than that and they need a refill too.
I appreciate you guys' sense of humor, but this isn't helping me resolve my problem. Is the root cause of this problem being that you can only run Novak speed controls with Novak motors?
Back when I got the speedo Novak specifically told me that it would run ANY motor I wanted as long as I was running less than 8 cells NiCd. Obviously we're two battery chemistries away from NiCd, but the input voltage is still far lower.
