T-birdJunkie
06.11.2011, 02:31 PM
Im guessing thats a brushed esc after seeing some pics of it.
Now STFU & GTFO you idiotic troll who knows nothing about escs & motors, or the ban hammer awaits...
You JUST figured that out?
It's a Novak Cyclone, FFS. I EVEN SAID THAT It literally took me thirty seconds to solder those motor leads (which came off my RS) to the speedo. And I'm still wondering how you think my solder joints are crap.
Originally Posted by slimthelineman View Post
Slimthelineman would expect nothing less from the funkyjunky and his phony credentials. Yup a three wire brushed controller will run a brushless motor fine! Ha ha.
FYI if your only cutting your comm every 10-14 race days your retarded. Brushed motors need more service than that. Your getting 30+ runs on a cut and set of brushess? Makes no sense. Even when I ran the round brush checkpoints I had to cut every ten runs or less to keep the motor runnin like a raped ape.
Why didn't you post this on rctech huh?
Because you and suicideneil are the only ones that are short-sighted enough to believe somebody that owned an RS Pro, a 10.5 and a 13.5 (which were all mentioned in this thread) would do this and expect it to work.
You guys are far too easy.
And if you had to work on your motor more often than that, then you obviously were running some crap Venom motors or something. And you missed the part where I said I'd clean the comm and change brushes between cuts.
Learn to read something other than erroneous electrical theory BS.
