b0gh0s
03.22.2006, 10:01 AM
Guys I ran into the same problem, I am trying to shrink down pics but I have them posted on my website, I will shoot pics of the individual parts this weekend. I can make the individual parts available, too
www.eaglesviewaerial.com/products.html
I just posted this to RCU the other day here is the relevant exerpts...
Since I have a small machine shop (2 cnc mills and a cnc lathe), I set out to build a BOLT ON KIT for the Revo that could be sold for less than 100 dollars in a retail setting, that would allow for a brushless drop in conversion.
To solve the gearing problem, after some messing around and searching, I found a suitable SAE pitch gear that Associated makes, and quite incidentally, it has three molded holes that were almost a perfect match to the 120 degree bolt pattern on the slipper!
So we keep the slipper (good thing), and now I had to just machine an adapter/spacer to get the gear mounted flat, (after 3 or for stripped gears I finally got one machined/sized correctly and now it is solid).
I had to lock the reverse shifter, very simple, a nicely bent piano wire and a bolt took care of it. Getting a good gear ratio (similar to the Emaxx overall G/R on a Novak system) using the stock gear box again, cheap and bolt on requires a lock up device on the second gear stage. I machined an ALU replacment hub for the second gear gearing that replaces the stock one way bearing hub that goes through it. Then you just ditch the first of the two stages of gearing, and use the lock hub so that electronic braking from the motor would work Viola! Works like a Charm!
Problem 2: Motor mounting
So I started with a hybrid motor mount of carbon and aluminum, the carbon gave too much flex and I went to an all aluminum machined two piece motor mount which allows gear ratio and mesh adjustments. (Older carbon verticle mount shown in pictures, I will shoot pics of the newer one this weekend)
Designed some simple and stiff carbon fiber trays that bolt into stock bolt holes on the chassis for the battery and ESC, and its done.
Performance:
Holy cr*p! I ran a 14 cell (cheap 3000mah NiMHs) and 4s2p TP Lipolies and it will wheelie on any surface even easing into the throttle, and is visibly faster than the nitro setup I had on my stock revo. The verticle CG remains very much the same, so the handling of the truck (other than off the line grunt which was not even close in the nitro setup) is very much the same. I went to stiffer springs in the rear to better support the battery weight and keep the ride hieght higher for my personal bashing terrain.
Price: The conversion kit is 74.99 retail, I am offering direct orders on www.eaglesviewaerial.com/products.html The only things you need to complete are BL motor, batteries of your choice, and a 14-19t pinion gear from Traxxas (from the Emaxx line). If you want to buy individual parts such as the lock up hub and gear mount for the associated gear, I can sell those individually, just call me directly.
Compared to well over 600 bucks for a complete gorilla max conversion, this offers a nice relatively cheap alternative.
Ok ok, pics, I can't post em because I took them in high quality format and don't have any of my image tools with me, check the website for detailed pics.
PLEASE NOTE THAT THE CARBON PORTION OF THE MOTOR MOUNT IN THE PICTURE IS NOW ALUMINUM....
(sorry, been out of town, need to shoot pics of the new mount piece).
I will post videos of it shortly, check my website for more details....
If you have any questions, please feel free to call or IM or email...
847-778-0874, (for IMs and email check profile).
