Hyper-5
The-Hyper One
Hyper-5's Avatar
06.20.2011, 05:33 AM
Originally Posted by ransom View Post
yes it does sound like a bad solder joint or battery connector or the esc is hitting low voltage cuttoff
is it a new install? new esc ?
is it set for the packs you are using?
check settings on the program card
if you dont have a program card for your xerun then you need one
it says 5.1v, on the speedometer, its sorta a new esc, the rest are all yes's
heres some pics of the join to the ESC, and the connection to the second plug og the ESC (in series)
seconf plug to ESC
plug from ESC thats goes into the battery
