asheck
06.23.2011, 01:43 PM
So Brandon, How about some facts. Easy yes or no questions.
Have you ever seen any of Max Amps cells handle a 150c load?
Have you ever seen any of the 6500mah packs, used at a reasonable discharge rate, use 6500mah?
Have you ever tested any Max Amps packs against other brands packs?
Did you see how many bad experiences had been listed, in the forum on RCtech?
