mothman
06.23.2011, 02:32 PM
Originally Posted by JasonB View Post
I've replaced both diff cups once, and one set of spider gears since I switched to the Hot Bodies cups. Still Very impressed with this upgrade!
What spider gears are you using? Is it the stock HPI ones? Since you are you using the HB cups, might as well use the HB hardened spider gears. From what Ive read, the are much stronger than the the HPI ones..
